Erro with File Bag Plugin
orca
Post by orca »
I have an error with the latest buld of InstallAware Studio which was already reported. See here:
Even applying the patch described in the other post, the error remains. The adress D:\Program is not referenced in anything inside my script or data I add. So, I'm not able to build a setup.
Ueli
Re: Erro with File Bag Plugin
Dear Ueli,
first of all there isn't any patch available, you only need to download the latest IA X2 trial (19.03) and then to install it (don't forget use a new re-generated license file to activate the product).
For what concerns the problem you are reporting, please follow the steps described with the following post.
http://www.installaware.com/forum/viewt ... f=2&t=9469
The error you are reporting seems caused by the "8.3 filename" settings with the drive you used to install IA.
orca
Post by orca »
seemed to be the problem. Other work around is to adapt the script variable manually.
