Problem with Copy/Move files
I cannot copy and move files from SQL Server Data folder to a normal folder. I have change to Native engine it still the same. Any criteria on copy files inside program files folders?
Re: Problem with Copy/Move files
Dear Ramu2020,
How do you copy such files/folders?
are both target and source files/folders available on target system when you try to copy them?
See the attachment on how I copy and delete file, I have check the source file is exist in the C:\Program Files (x86)\Microsoft SQL Server\MSSQL11.ESTOCKCARD3\MSSQL\Backup folder.
- Source File
- Capture2.PNG (38.16 KiB) Viewed 4712 times
- Script to copy and delete
- Capture.PNG (9.98 KiB) Viewed 4712 times
Dear Ramu2020,
I am not able to see any error with those IA commands ... please have a look at the attached ready to use sample (just build it).
It demonstrates Move/Copy/delete file(s) functionality.
- CopyMoveFile.rar
- (2.11 KiB) Downloaded 440 times
