Cannot write to registry
I'm using Write Registry function but it did not seem to do anything even I I put Apply Changes after that. Please help. Tq
- Capture.PNG (2.74 KiB) Viewed 4188 times
Re: Cannot write to registry
Did you check under the correct HKEY_LOCAL_MACHINE\SOFTWARE reg-key?
If you are installing a native 32 bit package on a 64 bit target OS, the SOFTWARE reg-key is re-directed to "HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node".
