Command Link Button
Command Link Button
Attached is a button in dialog I set the style property to bsCommandLink. The image arrow inside the button is pointing to the right. How can I change it to image that pointing to the left?
- CommandLink Button.PNG (1.51 KiB) Viewed 4694 times
Re: Command Link Button
Dear Ramu,
Unfortunately, you can't.
Alternatively, you could use an image control (to display a custom image) to replicate the button behavior.
Regarding image control as button, what is the best format and resolution, as I posted before we are having a sharp and good quality image file in PNG format, but when load to image control, the image don't look sharp but blur. I tried make sure the image resolution = size of the image control but still it look blur. It getting worse if it is stretch to the resize image control.
Any way I can insert vector image so that regardless the host pc resolution, font size etc, or the image control resize, the image still maintain the sharpness and quality?
