I would like to create a new dialog (not just a rehash/theme of an existing dialog). Is this possible to do as a plug-in? If so, is there an example of doing this?
Mike
New Dialog
There is no need to use plug-ins to create custom dialogs. You can just start with an empty dialog in the dialog editor and insert the controls you need. Then, you can double-click the buttons, text fields, and so on, to configure the actions they perform (such as going to the next dialog, capturing entered text into MSIcode script variables).
You can also of course show a custom dialog from a plug-in, but this will be an unnecessarily difficult approach for the simple task at hand. The dialog editor puts you in full control of your setup user interface with absolutely no manual coding effort.
Using the powerfull InstallAWARE scripting engine..Please look at the sample project to get an idea how it works..mreith wrote:So for a Memo or a RichEdit, how do I fill in the text or lines property at runtime? I would like to accomplish this from outside of the dialog.
Mike
Panagiotis Kefalidis
Software Design Team Lead
