Hi
I have an msi installer produced from an exe for use with Group Policy. I build the exe and then produce the msi using the group policy wizard.
When trying to install i get this error message at the Apply install line:
Error
The system cannot find the path specified
filepath.....
Would you like to try again?
Trying again doesn't seem to do anything.
If i use the exe from the install build the install seems to be ok.
The file does exist in the files to install. The conversion to msi seems to be going wrong for some reason?
Im using an older version of IA version 2012 - Build Moooya 9.26.11
I have no idea why its doing this because we have built this before. Im at a total loss
Any help would be greatly appreciated! even if its just to try and point me in the right direction??
Error - The system cannot find the path specified
Re: Error - The system cannot find the path specified
Dear Justin,
for what you are reporting, it seems an Anti Virus issue ... did you check it?
