Looking for Release Notes or similar for IA releases.
Sheri_Steeves
Postby Sheri_Steeves » Wed Feb 11, 2015 8:41 am
I noticed that a new release, IA1.07 was released in January. Is there a link or a web page that lists the fixes and updates for this version?
Sheri
Re: Looking for Release Notes or similar for IA releases.
Postby FrancescoT » Wed Feb 11, 2015 2:38 pm
Dear Sheri,
version 19.07 is a comulative update for IA X2 and it includes the following fixes;
- Generate Native Images failed with 64-bit .NET.
- Multi-Part archive extraction failed.
- Access permissions were not applied to the InstallAware folder.
- Customizing the setup elevation level lost Windows 10 support.
- The command line build module would not entirely terminate with 64-bit compression.
- Window minimize effects were disabled.
- Window positioning was lost when transitioning to other dialogs.
- 32-bit window transition effects had display artifacts.
- Transitions displayed dialog accelerators incorrectly.
- Transitions displayed text wrapping incorrectly.
- Localizations were pre-applied.
- Simultaneous command line compilations would fail.
- Various application pinning issues.
- The Pre-Compiled Application Runtimes tool would fail.
- The Dialog Editor did not cooperate with Team Foundation Server.
- Various IDE tools required elevation to work correctly.
Sheri_Steeves
Postby Sheri_Steeves » Fri Feb 13, 2015 12:29 pm
Thanks!
Users browsing this forum: No registered users and 135 guests
