I have the following requirement:
I need to create a folder during install, to which I add a share name and assign permissions. When I uninstall (or updgrade) my product I do not want to remove this folder; my user's my have made some changes to the security and permissions on this folder that they want to keep.
Right now if the install process creates the folder (using the CreateFolder command before ApplyInstall), it is also removed during uninstall.
I tried using CreateDirectory but no folders are created; I suspect because I am calling it after ApplyInstall.
How can I keep InstallAware from removing that folder?
Sheri
Create a Folder during install but don't delete it upon uini
Sheri_Steeves
Re: Create a Folder during install but don't delete it upon
Dear Sheri,
please have a look at the following link that describes how to execute a Windows Installer command immediately (not deferred to "apply install" execution). In this way the command will be not part of the MSI database and consequently, no action will be executed at un-install time.
http://www.installaware.com/forum/viewt ... =2&t=10212
You could also Run Program CMD.exe /C MKDIR mynewdir
Sheri_Steeves
Francesco, Adam
Thanks for the information; looks like one if those will be what I need.
Sheri
Sheri
