Weird display issue with IA X2
Mohamed Koker
Post by Mohamed Koker »
Hi Francesco,
We are experiencing a strange display issue when we run our installer on some computers using IA X2.
I suspect the translation tables need to be rebuilt.
Can you please let me know I would go about doing this or if there is something else I need to do to prevent this issue?
Thanks in advance
-Mohamed
Fortune passes everywhere
Re: Weird display issue with IA X2
Dear Mohamed,
localized strings may cause problems if not exactly synchronized with the latest script code modifications.
You may try to re-generate all your localized strings and then re-import them back once again in your project.
