Error 1406 on writing a registry value
hdwivedi23
Postby hdwivedi23 » Thu Mar 19, 2015 8:59 pm
I am got following error while installation
"Error 1406. Could not write value BrandList to key \SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\{ProductCode}. System error . Verify that you have sufficient access to that key, or contact your support personnel."
I am trying to write BrandList Value under \SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\{ProductCode} using
Write Registry Key HKLM\$MC_REGISTRYKEY$\BrandList, $MC_BRANDLIST$
If I ignore the error the rest of the installation is performed successfully. When registry key Uninstall\{ProductCode} is created without any issues then why there is an error related to permission on writing a value to an existing registry key. After all, both values are written by Windows installer.
Can someone please help me resolve this issue.
Re: Error 1406 on writing a registry value
Postby FrancescoT » Fri Mar 20, 2015 1:22 pm
Dear hdwivedi23,
even if such registry location should never be used to store custom application data, I am not able to replicate your issue.
I just used the following code to store a dummy value under the "Microsoft Visual C++ 2008 Redistributable" uninstall registry path and worked fine.
(HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\{1F1C2DFC-2D24-3E06-BCB8-725134ADF989})
Comment: Write and entry to "Microsoft Visual C++ 2008 Redistributable" UnInstal REG-KEY
Write Registry Key HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{1F1C2DFC-2D24-3E06-BCB8-725134ADF989}\MyValue, Value
~InstallAware Clipboard Data~
~Write Registry~
~{361E68FD-B68A-4972-B70E-38E24E18BE98}~
~0~
~2|~
~SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{1F1C2DFC-2D24-3E06-BCB8-725134ADF989}~
~MyValue~
~Value~
~TRUE~
~FALSE~
~Comment~
~{1DE1C427-8A49-4783-BECA-E7A6E789D1CF}~
~Write and entry to "Microsoft Visual C++ 2008 Redistributable" UnInstal REG-KEY~
~Comment~
~{424E7239-80C8-4862-B8AC-CA463E4D03ED}~
~Set Variable~
~{A3B2D90D-7317-4158-BD5F-4F2DD91133CC}~
~NATIVE_ENGINE$MYAH$MYAH$FALSE~
~TRUE~
Users browsing this forum: Baidu [Spider] and 153 guests
