When building the setup I receive an error message saying "No files matching wildcard pattern...". It appears the setup process is looking for some runtime files that I elected not to install. The message does say to run InstallAware setup again add all optional features.
My reason for not installing is because these runtimes are already installed on the systems where this install is to take place. Is there a way (in the VS add-in version - free) to eliminate the inclusion of these runtime files?
VS2013 Build Setup run-time files
Re: VS2013 Build Setup run-time files
Dear HenryOfPlano,
you must install all the runtime features required to correctly build your package.
The fact that you have the same Runtime files already installed with your system, has nothing to do with the Runtime installer packages that need to be included with your setup.
Unfortunately the ability to selectively include or exclude a specific Runtime, it's not available with the FREE edition of InstallAware.
Users browsing this forum: No registered users and 100 guests
