With InstallAware X2 Studio the "Does File/Folder Exist" feature appears to be broken.
I have a script written in 2012 Studio that detects a UNC folder, and then if it doesn't exist creates a network share.
When run in InstallAware X2 studio, the same script returns a true value whether the folder path does or does not exist.
Is there a patch I can apply to remedy this problem?
Find directory doesn't work with UNC paths
EpicorRelease
- InstallAwareDetectError.doc
- (58 KiB) Downloaded 388 times
Re: Find directory doesn't work with UNC paths
just tested ... but I am not able to replicate the same.
For what I see the "Does Folder Exist" command correctly returns the existence of UNC folder and only, if the same effectively exists.
If you can post a very minimal project that replicates the issue, I'll be happy to verify it.
