WINDIR in Windows 2008 R2 Terminal server
rbarat
Post by rbarat »
While running the installation on Windows 2008 R2 with Remote desktop services (Terminal Server) the WINDIR and ALLWINDIR varibales are wrong. They return both "C:\USERS\<user>\Windows" instead of "C:\Windows".
It is done by your automatic generated commands:
          Get Folder location System->Windows Directory into WINDIR
          Get Common Folder Location System->Windows Directory in ALLWINDIR
Please notice that your built in scripts which check if components exist (like checkvc10_x86) refer to $WINDIR$\WinSxS and never find the installed components which are installed on "C:\Windows\WinSxS".
Raffi
Re: WINDIR in Windows 2008 R2 Terminal server
Dear Raffi,
honestly I suppose there is something wrong with your code.
The default script code generated by IA, it's instead;
Get Folder Location System->Windows Directory into WINDIR
Get Folder Location System->System Directory into WINSYSDIR
The same as IA Clipboard Format;
~InstallAware Clipboard Data~
~Get Folder Location~
~{A34B113B-2347-40D3-B20B-575F114BA95A}~
~WINSYSDIR~
~23~
~FALSE~
~{FD92E8F0-D7DA-44A0-A16C-7B621AEA0F2D}~
~WINDIR~
~25~
~FALSE~
Anyway, using the above code both target system's folders are returned correctly.
rbarat
Post by rbarat »
Sorry about my mistake. I typed the code manually and did not type it correctly.
Our code should be correct because it works fine in our complex installation project.
The installation works fine and and was already used in many operating system (XP, 2003, 7 x86, 7 x64, 2008, 2008 R2 and 2012).
It includes the default code.
WINSYSDIR in C:\Windows\System32 or C:\Windows\SysWOW64 which is fine
But we have a problem with WINDIR.
In most of the cases its value is OK (C:\Windows).
But in Windows 2008 R2 which is a Remote Desktop Server (terminal server) the value of WINDIR is different
It is C:\Users\<user name>\Windows
We tried to use the common Windows variable which you provide But it has the same value as WINDIR
We added it from Desigen \ Files \ Add system Folder.
Get Common Folder Location System->Windows Directory into ALLWINDIR
Attached is also the clipbaord code
~{794173E2-153D-4936-9B36-82BC59F65A9C}~
~ALLWINDIR~
~25~
~TRUE~
~{EB87E659-BED5-4A7C-A3AB-2A5E0FD47ECD}~
~WINSYSDIR~
~23~
~FALSE~
~{8BB7B33F-7D86-440C-89D0-8E769A03D2AB}~
~WINDIR~
~25~
~FALSE~
Dear Raffi,
I just tried once again, with creating a new blak project from scratch that only uses the following code.
Set Variable WINDIR to
Set Variable WINSYSDIR to
MessageBox: Debug, WINDIR=$WINDIR$$NEWLINE$WINSYSDIR=$WINSYSDIR$
... and these are the results.
Attached you find the project along its executable (I used IA X2 ver. 19.08).
blank.rar
(3.81 MiB) Downloaded 390 times
