hello:
is it possible to instead of having a message telling me about placing an index.htm file with my project on the install progress screen to just have a breen backdground for the progress dialog in the emerald theme and related themes. are there any specific requirements for such an index.htm file?
REG: Emerald Thee install progress question
Carly Grace Fleischmann:
[color=#0000BF]Call Center Tech by Day, beginning programmer and install Dev by nigh, what could go wrong with that?
... Trust us, you don't ant to know!
[/color]
~~ Please remember: don't text and drive ~~
[/color]
Re: REG: Emerald Thee install progress question
you can remove the "HTLM control" from the dialog using the Dialog Editor tool, then you can apply any background color (if not already defined).
For the index.htm file requirements, please have a look at "Using Interactive Progress HTML" within the IA documentation.
Alternatively for a sample, create a dummy project from scratch and switch to the "Attractive" dialog theme in the project dialogs settings.
This will add a ready to use "index.htm" file to the project.
Users browsing this forum: No registered users and 97 guests
