Language Selection not working
mwilner
Postby mwilner » Fri May 01, 2015 3:48 pm
I have a similar problem as described here: Runtime error in install: List index out of bounds. (76) viewtopic.php?f=2&t=2042&start=0
now there are two suggestions, 1 the Registration.exe is an old one and 2 there is an issue in the if/else clause.
In my case I can't find any issue with the if/else clause in the script file that is causing the error and I can't find any information about the Registration.exe either.
What is the deal with this application? I can't find a reference in the customer area either.
My original project was created with an earlier version of IA and I am working in IA15 right now as I didn't want to re-write all the language references, etc. and I had to debug the code because the Language selection process wasn't working.
Before I reapplied the localization the project worked started the Language selection dialog and showed all languages but now it fails.
Hope that there is a simple solution.
Best regards,
Manfred Wilner
Manfred Wilner
Re: Language Selection not working
Postby FrancescoT » Mon May 04, 2015 12:56 pm
Dear Manfred,
did you try with re-importing your localized strings having care to re-generate all the used strings?
If you used the IA 15 string editor tool, your edit language references should be still there. You can easily verify this running the "translation tool".
mwilner
Postby mwilner » Tue May 05, 2015 3:43 pm
Hi Francesco,
I had renamed the Product Name but didn't know that this will have an affect on the translation.
Now that I also renamed the Translation .mtx file the project works again.
Thank you for your help.
Manfred Wilner
Postby FrancescoT » Wed May 06, 2015 12:23 pm
:D
Users browsing this forum: No registered users and 134 guests
