Context sensitive help
When I press F1 context sensitive help comes up with a list of topics on the left. But when I click display nothing shows up.
- IAx2Help.pdf
- (129.86 KiB) Downloaded 376 times
Re: Context sensitive help
if the InstallAware help file is not damaged or corrupted (C:\Program Files (x86)\InstallAware X2\miae.chm), probably there are some problems with the "Microsoft Windows Help utility" executable (C:\Windows\hh.exe). You may try to verify if the same problem can be replicated launching other "CHM" files. If true, the problem is surely caused by the "Microsoft Windows Help utility".
No problems launching other .chm files. Must have a damaged miae.chm.
How can I get another copy of the file?
Ken Kight
Ken Kight
Francesco
Downloaded the file and it still is not working. I had loaded the InstallAware package to a mapped H: Drive so I uninstalled it and loaded it on my local C:, still no display on the right hand side of the help window. Is there a problem with IE11 and the help file?
Ken Kight
Ken Kight
Dear Ken,
it can't be a compatibility issue win IE11 ... I have IE11 installed and works fine.
Instead I suspect there is something with your system at the root of your issue.
