Importing IA project from IA installer executable
jweksej
Postby jweksej » Wed May 27, 2015 3:47 am
I have InstallAware installer done as single-file-executable.
Is there any way to extract InstallAware project from it, as a way to continue development :?:
It will save me a lot of time...
thanks in advance for any help
Jarek
Re: Importing IA project from IA installer executable
Postby FrancescoT » Wed May 27, 2015 1:13 pm
Dear Jarek,
you may use "PackageAware" tool to import any setup into an InstallAware project.
PackageAware is an intelligent wizard that captures the changes a setup makes to a system. You may use PackageAware to monitor the results of any installation, and it will create a ready-to-use installation project that can be immediately built in InstallAware. PackageAware provides a very easy way to migrate legacy installations into Windows Installer, and InstallAware.
You can find more details with the InstallAware documentation.
Users browsing this forum: No registered users and 80 guests
