Automatic configuration of the update wizard
gibbie99
Postby gibbie99 » Wed Jun 03, 2015 1:34 pm
I am using the web updates in version InstallAware X2 Studio Manager. Currently there is user feedback where they would like to disable the required logoff after install to set up the scheduled task to search for updates, is there any way I can script the generation of this task? Basically I'd like some code that automatically configures a task to run at 3am every sunday to hit the website and search for updates.
Thanks!
Re: Automatic configuration of the update wizard
Postby FrancescoT » Wed Jun 03, 2015 2:13 pm
Dear Gibbie99,
let me see if I still have a test project that should do what you are searching for.
gibbie99
Postby gibbie99 » Wed Jun 03, 2015 2:27 pm
Thanks Francesco!
Postby FrancescoT » Mon Jun 08, 2015 11:55 am
Dear Gibbie99,
You can download the "WebUpdate sample (customized)" sample from the link below.
http://www.installaware.com/forum/viewtopic.php?f=2&t=6772&p=25655#p25655
gibbie99
Postby gibbie99 » Thu Jun 11, 2015 3:38 pm
Thanks! I'll take a look ASAP.
gibbie99
Postby gibbie99 » Mon Jun 22, 2015 3:31 pm
I was able to get this working very easily, thanks!
Postby FrancescoT » Tue Jun 23, 2015 11:58 am
:D
Users browsing this forum: No registered users and 113 guests
