Check for Process
kurtkroeker
Check for Process
Postby kurtkroeker » Wed Jul 01, 2015 3:06 pm
I'm working with InstallAware Studio and I'm attempting to check to see if Excel is running, and if it is, to close it. I'm using your Check for Process command to do so, and I'm referring to your documentation found here: http://www.installaware.com/FlashHelp/checkprocess.htm.
However, I'm unable to reproduce your example using Windows Explorer. Here's my code:
Comment: Check to see if Excel is open or not
Set Variable excelIsOpen to True
Set Variable dialogResult to
Check for Process "excel.exe", get result into variable excelIsOpen
if Variable excelIsOpen Equals True
MessageBox: Close Excel, The installer has determined that Microsoft Excel is currently running and must be closed before continuing.$NEWLINE$$NEWLINE$Click OK to close Excel or Cancel to exit the installer.
 if Variable dialogResult Equals OK
   Terminate Program Excel
   else
   Terminate Installation
No matter what, I can't get excelIsOpen to be True. Is there a bug with Check for Process, or am I missing something else?
Many thanks,
Kurt Kroeker
Re: Check for Process
Postby FrancescoT » Thu Jul 02, 2015 12:50 pm
Dear Kurt,
did you verify if the process name is correct?
For example, recent versions of Internet Explorer have "iexplorer.exe" as process name.
you can check the names of the running processes from Task Manager (CTRL+ALT+DEL), then enter the same name with command.
kurtkroeker
Postby kurtkroeker » Thu Jul 02, 2015 3:54 pm
Hi Francesco,
Thanks so much for your reply! Here's the info I have from Task Manager when Excel is open:
Name = "Microsoft Excel"
Process name = "EXCEL.EXE"
And when I expand the Microsoft Excel process, it shows one child with Name = "Excel".
I've tried the following for the Process Name (executable file) field in the Check Process dialog:
* excel
* EXCEL
* excel.exe
* EXCEL.exe
* Excel
* Microsoft Excel
...and none of them have worked. When I run Get-Process *excel* in PowerShell, I get this:
Handles NPM(K) PM(K) WS(K) VM(M) CPU(s) Id ProcessName
746 40 40248 74240 458 1.48 15356 EXCEL
When I run the same command with -FileVersionInfo, I get this:
ProductVersion FileVersion FileName
15.0.4727.1000 15.0.4727.1000 C:\Program Files\Microsoft Office\Office15\EXCEL.EXE
I expect ONE of those variants I posted above is the "right" input, but I've tried them all with the same result...
kurtkroeker
Postby kurtkroeker » Mon Jul 06, 2015 9:14 am
I'm assuming the Check for Process command works for other people...Can anybody post a snippet for me that they know works?
Postby FrancescoT » Mon Jul 06, 2015 10:49 am
Dear Kurt,
using the following code I am able to check for a "notepad" process and if this is running, it gets terminated.
~InstallAware Clipboard Data~
~End~
~{0392201B-CD9E-4B96-8E1D-59F2517AF517}~
~MessageBox~
~{20C32E7C-F926-4703-881D-65EC7D539608}~
~TASK_RESULT = $TASK_RESULT$~
~0~
~1~
~Terminate Process~
~{A52E5DE5-A9BF-49AE-B8D5-6F935CBB1E28}~
~$PROCESS_NAME$~
~TASK_RESULT~
~If~
~{0CB66A66-36B1-4F08-A5DF-A2A959674CDE}~
~TASK_RESULT~
~0~
~TRUE~
~FALSE~
~Check Process~
~{061A48A6-1F3A-433B-BEB6-F263154082BF}~
~$PROCESS_NAME$~
~TASK_RESULT~
~Set Variable~
~{8DA0412C-20E8-47E5-B4A2-0FCB7B9C8389}~
~PROCESS_NAME$MYAH$MYAH$FALSE~
~notepad.exe~
~Set Variable~
~{268B95E2-CC8D-4C18-8C37-3588776DA9BA}~
~TASK_RESULT$MYAH$MYAH$FALSE~
To make a simple test;
- create a new project from scratch using the "BLANK" project template
- copy the above code (in IA Clipboard Format) and paste it in the main script.
- Build the project and test on target machine where a notepad process is running.
kurtkroeker
Postby kurtkroeker » Mon Jul 06, 2015 12:22 pm
Thanks again, Francesco.
I tried your example but was unable to get it to work. Perhaps my environment has something to do with it?
Windows 8.1 Pro 64-bit
InstallAware Studio
InstallAware X2 (Build 4.03.15)
I do not have Admin privileges
Attached are my testing results from the example.
EDIT: The attachment appears to have not come through. Here's a link to the screenshot: https://drive.google.com/file/d/0Bzczgm ... sp=sharing
Postby FrancescoT » Mon Jul 06, 2015 12:30 pm
Dear Kurt,
the setup process has to be elevated otherwise you will be not able to detect notepad running ( expecially if notepad runs under a different user context).
kurtkroeker
Postby kurtkroeker » Fri Jul 17, 2015 12:00 pm
Just to close the loop on this, it would seem that this solution isn't going to work for me since it's a requirement for my installer that the user NOT require Admin elevation to install the product.
Thanks very much for your help, Francesco!
Users browsing this forum: No registered users and 54 guests
