Unable to uninstall? after finish process in Add/Remove Icon
danieltan
Postby danieltan » Tue Jul 14, 2015 4:56 am
Mind to ask what kind situation unable to uninstall completed clean?
Scenario:
1. I got two version installer which is v1.0.0 and v1.0.1.
2. I go install v1.0.0 and after that install v1.0.1 in my machine.
1. Go to Add/Remove Icon(Control Panel) launch uninstall application
2. The installer help completed uninstall and the icon installer is disappear (in control panel).
3. I found on the Start menu, still have all those shortcut exist
i). Uninstall Product
ii). Product Update
iii). product.exe
4. When I click on these icon, it showing Missing shortcut
5. I try to install existing installer v1.0.0, it directly display error message as below:
For your information, my installer does not contain any Install Application Pre-Requisites which just briefly with our installer files only and also have Web update script.
Re: Unable to uninstall? after finish process in Add/Remove
Postby FrancescoT » Tue Jul 14, 2015 1:24 pm
Dear Daniel,
please don't use multiple channels to post the same question.
For what concerns the project you sent, this is not complete and at least a script file was not included.
Please send your project along with any single file it uses in a compressed archive.
Otherwise it will be impossible for us to open and then to test it.
Possibly send to us a very very minimal project that replicates the issue.
danieltan
Postby danieltan » Tue Jul 14, 2015 8:43 pm
I manage found the answer.
This is because:
Previous
Comment: IMPORTANT!
Comment: If your setup uses the Native Engine,
Comment: And the Scheduled Web Update Mode;
Comment: Comment-in (enable) the line below:
Now
Comment: IMPORTANT!
Comment: Set Variable NATIVE_ENGINE to TRUE
Currently the system run perfectly after the changed.
Does it mean whenever there is a Variable for NATIVE_ENGINE been turn TRUE and after doing something on code require to turn it FALSE.
Or as long it related with Schedules Web Update mode, variable of NATIVE_ENGINE should not exist.
By the way, FrancescoT mind to help me enlighten the question been posted at http://www.installaware.com/forum/viewtopic.php?f=2&t=10359
Users browsing this forum: No registered users and 54 guests
