Install certificate
mikKummerfeld
Install certificate
Post by mikKummerfeld »
Hello Guys,
how can we install/import a certificate (e.g pfx) during setup process. In order to make our new ssl/https connection possible, we want to automate this process in the setup process.
I didnt found a code command "install cert" or something.
Heiko
Kind regards
Heiko Kummerfeld
MIK GmbH
Head of quality assurance
technical consultant
Re: Install certificate
Dear Heiko,
it's not quite clear to me what you effectively need to do with such certificate, but anyway there are no command available at this purpose.
I don't know, but Probably you may try to call a "TOOL" that does what you need from your setup.
