I am receiving an error when running the un-installation of my installer. The error states: Unable to load plug-in library. Please rebuild your project and make sure all required plug-ins are installed. Action skipped". I do not get any plug-in errors on install, just uninstall. There is also no mention of what plug-in is causing the issue. Why would this show up on uninstall and how can I determine what is causing the error?
plug in error on uninstall
Re: plug in error on uninstall
Dear Mark,
you should verify the part of your script code that effectively does the un-install process.
By default there are two parts in the main script code which are responsible of the un-install process.
1-The first gets executed when the un-install runs within a Product Update process (Install Application Pre-Requisites - Code Region).
2-The second instead when the installed application is removed from Add Remove Program (Perform First Time or Maintenance Installation - Code Region).
That said and by default, only the script code described at point ONE uses a plug-in and more specifically, the "(Un)Install MSI Setup" plug-in.
Users browsing this forum: No registered users and 53 guests
