Hello Guys
I have been building new Customized a setup but I could not get the files to be installed
Every time, I click install,it Installs no files and it seems nothing is happening. Even-though I used Apply install in the script
Regards, Nasr
Files not being Installed
- NeoEE Installer.rar
- (1.13 MiB) Downloaded 449 times
Re: Files not being Installed
waiting a help
thanks
thanks
Dear Afrqan,
it's impossible to test the project you posted.
Your attachment only includes the project and not the files it should install.
In addition the package seems to be just an upgrade for an existing application, which seems to be required in order to install "your project" correctly.
