how is it possible to change the condition in "Display dialog - if variable" from TRUE to FALSE? The both radiobuttons seem to be deactivated.
Did i miss here something?
- Display dialog
- Unbenannt.png (5.05 KiB) Viewed 11630 times
Re: Display dialog - if variable
Yes ... you missesd to enter a variable name with the "If variable" field.
Dear Francesco,
no sorry - i already entered a variable (see second screenshot). Sorry i did forget to write this down.
But the field never gets enabled. Any further ideas?
edit: I am using Installaware Studio 12, running on Win 8.1.
- 2015-09-01 09_53_44-Display Dialog.png (5.2 KiB) Viewed 11616 times
Dear Christ23,
Really strange!
I am not able to replicate the same ... however I can only use IA X3 now.
Creating a new project from scratch, do you see any difference with the default "Display Dialog" statements?
Really strange!
Dear Francesco,
i got it! Creating a new project from scratch did not help.
BUT, i discovered something: When i insert a variable in the condition-field, the radiobuttons still are deactivated. But now, when closing the "display dialog" and re-opening it, then the radiobuttons are enabled. Seems that the radiobutton-enabling only works when re-opening the dialog.
So this issue is resolved. Anyway, thanks for your help.
