I am checking for pre-requisite before installation and install those if needed.
Now on uninstall the same routine is checking for pre-requisites and wants to install them again even if you uninstall the application.
How can I avoid this from happening?
Best regards,
Avoid check for pre-requisite on uninstall
Manfred Wilner
Re: Avoid check for pre-requisite on uninstall
Dear Manfred,
I suppose this happens because you altered the default main script behavior.
I suggest to you and for test "purpose", to create a new "dummy" project from scratch and then to include an Application Runtime to the project.
In this way you will see where the respective "check" and "setup" Runtime scripts are sequenced within the project main script.
In your case I have the feeling that a "check" Runtime script, has been "erroneously" sequenced around the "Perform Uninstallation CODE REGION" of your main script.
Hello Francesco,
Thank you for the quick reply.
The check runtime script is in the CheckApplication Pre-Requisites region and apparently this is run through even on uninstall.
I wasn't sure if the MAINTENANCE variable would work in the region but it seems to work. So I am checking if this variable is not true and only then do the check for runtimes.
Is the installer supposed to run through this CheckApplication Pre-Requisites region?
Best regards,
Best regards,
Manfred Wilner
Dear Manfred,
check within the "Install Application Pre-Requisite", the relative "setup rtm" script should be within the "if Variable PREREQ not Equals FALSE" block ...otherwise it could be executed Always.
Hi Francesco,
Thank you again, yes this is the case.
The actual problem is not the installation of the pre-requisite rather the check for it as sometime this can take a very long time and while you are uninstalling it doesn't seem to be needed to have the pre-requisite fulfilled.
It seems odd to me that this happens.
Best regards,
Best regards,
Manfred Wilner
GFXDude2010
I too altered the default installation logic, before realizing the "suggested" route is essentially the best route. Rather than recreating the project from scratch, I opted to just check the Pre-Defined variable REMOVE in my Check Application Pre-Requisites Region.
[DEFINE REGION: Check/Install Application Pre-Requisites]
[DEFINE REGION: Check Application Pre-Requisites]
label: Check Application Pre-requisites
if Variable REMOVE Equals FALSE
Include Script: checkPreRequisites
if Variable PRELIST not Equals
Display Dialog: prereq, wait for dialog to return (modal)
if Variable WIZARD Equals BACK
GoTo Label: Welcome Dialog
if Variable WIZARD Equals CANCEL
Display Dialog: cancel, wait for dialog to return (modal)
Terminate Installation
<<Code Folding Region>>
[DEFINE REGION: Install Application Pre-Requisites]
label: Install Application Pre-requisites
Include Script: installPreRequisites
Users browsing this forum: No registered users and 149 guests
