Evaluate XPath command
Frank
Post by Frank »
I've got an XML like so (thank you W3schools :) ):
<?xml version="1.0" encoding="UTF-8"?>
<bookstore>
<book>
  <title lang="en">Harry Potter</title>
  <price>29.99</price>
</book>
<book>
  <title lang="en">Learning XML</title>
  <price>39.95</price>
</book>
</bookstore>
And I've got code like this:
~InstallAware Clipboard Data~
~Evaluate XPath Query~
~{A280858C-6078-45D2-A0D1-348959A6AAC8}~
~"C:\hello.xml"~
~BLUT~
~0~
(which translates to)
Evaluate Query / on XML "C:\hello.xml", get result into variable BLUT as type Full XML String
Running this I would expect the variable BLUT to contain the whole XML, but it returns empty.
I wanted to get a value deeper than root, but since that didn't work either (bookstore/book/price).
So I tried to get the whole thing, but even that doesn't work.
What am I doing wrong? :oops:
Re: Evaluate XPath command
Dear Frank,
you cannot use the "Evaluate XPath Query" command to get the Whole xml file content, If you need so, you may use the "Read from Text File" command instead.
For what concerns the "Evaluate XPath Query" command syntax, please have a look at the attached sample and to the following links.
http://www.installaware.com/forum/viewt ... xml#p37774
http://www.installaware.com/forum/viewt ... f=4&t=9456
XPath.rar
(1.73 MiB) Downloaded 439 times
Frank
Post by Frank »
After some experiments I got it working.
It had to do with several (nasty :roll: ) oversights on my side.
First off I concatenated a filename to a filepath, leaving me with a folder like:
c:\program files (x86)\My Company\My Product\Configuration.xml\Configuration.xml which doesn't exist.
Next, the XPath query is case-sensitive!! That'll throw you off guard. I (now) know it's in the XPath specs, but mentioning this in the help would be appreciated!
Third, using the wrong Result Type: I needed Node Text, but requested Node Value. That'll never match ofcourse.
Anyway, it's working.
Thanks for the input (once again).
:D
