Hello Guys,
i bought the plugin and it works very well, but one questions which I think is very bad:
if setup variable "SingleInstance=FALSE", the second loaded setup shows the trial license box from cryptography
Please fix it and provide update
Heiko
DF-Cryptography Plug-in TrialMessage
mikKummerfeld
Kind regards
Heiko Kummerfeld
MIK GmbH
Head of quality assurance
technical consultant
Heiko Kummerfeld
MIK GmbH
mikKummerfeld
Re: DF-Cryptography Plug-in TrialMessage
Any update?
Kind regards
Heiko Kummerfeld
MIK GmbH
Heiko Kummerfeld
MIK GmbH
digitalfarm
Dear Heiko,
unfortunately what you are reporting is due the protected context the plug-in uses to keep its data.
For this reason. I am not quite sure if it will be possible to fix this SINGLEINSTANCE issue.
For any future question, please use any of the following dedicated topics. These will be also used to announce plug-in updates or fixes.
http://www.installaware.com/forum/viewt ... f=2&t=9854
http://www.installaware.com/forum/viewt ... f=3&t=8460
Thanks!
Thanks!
