Dialog Object changes upgrading to 18
hkeller
Post by hkeller »
I recently upgraded from Installaware12 Studio to Installaware18 Studio and noticed that the font property for dialog objects no longer is a dropdown, but a text field requiring you to manually type the font type. I have also noticed that the AeroPngImage object no longer autosizes to the size of the image loaded. Are these know issues?
Re: Dialog Object changes upgrading to 18
Dear hkeller,
honestly I don't recall how it was exactly on IA 12 with the Font property.
Did you select the (...) button?
Regarding the Auto-size with the AeroPngImage, for now I can only say that unfortunately, it seems to be as you reporting.
hkeller
Post by hkeller »
Strange, I reinstalled 18 and now see the (...). Previously the issue was the (...) was not showing, even after resizing that window. I don't know what happened, but it seems to work now.
:D
