Remove the 'Start Program' checkbox?
sfaust
Postby sfaust » Tue Oct 13, 2015 1:24 pm
I develop mainly programs that are a plugin that runs inside another program, so there is no exe to start my program. I would like for it to install and just show the finish screen without giving the user the option to 'start program now' since there isn't anything to start. I don't see any option to do this without possibly having the studio version which is much more expensive than developer and I really don't want to have to purchase that just to remove the checkbox... Is there a setting I'm missing to remove that item?
Re: Remove the 'Start Program' checkbox?
Postby FrancescoT » Tue Oct 13, 2015 1:52 pm
Dear Sfaust ,
Unfortunately it's not possible to modify such dialog without having the Dialog Editor.
http://www.installaware.com/forum/viewtopic.php?f=2&t=5777
http://www.installaware.com/forum/viewtopic.php?f=2&t=2711&start=0
Return to “Non-Technical”
Users browsing this forum: No registered users and 2 guests
