updates are being installed loop
tofutim
Postby tofutim » Wed Oct 21, 2015 6:16 pm
Hi, I have been using the Installaware update feature (Installaware X2). On a recent update I now have "the updates are being installed" popping up over and over again in an infinite loop. What causes this? What am I missing?
Re: updates are being installed loop
Postby FrancescoT » Thu Oct 22, 2015 11:35 am
Dear Tofutim,
did you check if the cause is the Anti Virus (if any)?
tofutim
Postby tofutim » Thu Oct 22, 2015 3:46 pm
I found the problem. I got carried away and had 8.0.1.657=myapp 8.0.1.657 in my updates.ini and it was going infinite loop on me!
Postby FrancescoT » Fri Oct 23, 2015 11:54 am
Happy you solved!
Users browsing this forum: No registered users and 91 guests
