Our customer changed the server and reinstalled our apps via InstallAware script. Script complains "Could not access network location network path" and shows old network path. Any suggestions what is needed to be cleaned up, or how script should be modified? We are using NativeEngine=true.
Re: Could not access network location network path
Dear Galina,
it seems you have an invalid path specified somewhere with a script command, but it's quite difficult to identify the offending statement without having your code.
Did you get any chance to isolate the script command that generates the error?
For what you are reporting, I suppose this occurs when you run the package in maintenance mode (REPAIR).
If this is true, please note that in REPAIR mode the setup will repeat the installation as it was originally installed.
This means that the REPAIR process will reuse the same identical parameters that was used to install the package.
So if this is the case, this is not an error ... instead it's the installation that should be repeated from scratch (uninstall -> install).
Thank you! We found the problem. We had Install/Remove MS package in script and it generated the error about none-existing path. We do not require "true" uninstall in our case, so commenting this call is the solution.
Happy you solved!
Users browsing this forum: Kostya and 103 guests
