Setup built with Installaware X3 hangs during installation
Anil
Postby Anil » Sun Nov 01, 2015 11:39 pm
When ngen.exe from Microsoft Framework v2.0.50727 is executed in Installaware setup using "Run Program As" command, some antivirus software like AVG are blocking the execution of this command and there by the setup hangs during installation. This behavior is observed with Installaware version X3 setup, the same works fine with Installaware version 9 setup. Also, when the same command is executed from command prompt manually, it works fine even with AVG antivirus running.
Can you suggest what could be the problem and how to address it?
Ngen command used:
C:\Windows\Microsoft.NET\Framework\v2.0.50727\ngen.exe install "XXXX.Win.SupportDialogs.v12.1,Version=12.1.20121.2050,Culture=neutral,PublicKeyToken=7dd5c3163f2cd0cb, processorArchitecture=MSIL"
Re: Setup built with Installaware X3 hangs during installati
Postby FrancescoT » Mon Nov 02, 2015 12:30 pm
Dear Anil,
unfortunately there isn't so much that I can suggest you. We inform all AV manufacturers about our products ... but some of them are not very responsive.
Generally it should be enough to digitally sign the package.
Anil
Postby Anil » Mon Nov 02, 2015 10:48 pm
Appreciate your prompt response.
The setup is digitally signed. Inspite of a valid signature this issue happens for pack built with IA X3.
Anil
Postby FrancescoT » Tue Nov 03, 2015 1:27 pm
Dear Anil,
this is clearly a false positive... unfortunately.
Users browsing this forum: No registered users and 73 guests
