How to display webpage in HTMLViewer
georgesak
Post by georgesak »
I am trying to display a web page report.htm (which, let's assume, found on C:\myinstallation\) in HTMLViewer.
When the dialog opens, I am unable to display it.
I tried adding index.htm file under Support Files with <meta http-equiv="refresh" content="0; url=C:\myinstallation\report.htm" /> at the top, it is not redirecting.
Is there a way to do this?
Re: How to display webpage in HTMLViewer
Dear Georgesak,
if you have a look at the IA documentation about "Using Interactive Progress HTML", you will see;
"Make sure none of the links on any of the pages has path specifiers - everything should work in a flat directory structure."
