No entry in the ADD/REMOVE Programs list
wxperson99
Postby wxperson99 » Tue Nov 17, 2015 7:35 pm
Is there a way to prevent a very small installer I have from creating an entry in the Add/Remove Programs list?
George
Re: No entry in the ADD/REMOVE Programs list
Postby FrancescoT » Wed Nov 18, 2015 12:15 pm
Dear George,
Please have a look at the following link.
http://www.installaware.com/forum/viewtopic.php?f=2&t=9400&start=0
wxperson99
Postby wxperson99 » Wed Nov 18, 2015 12:30 pm
So if I read this correctly.
Provided I don't execute the APPLY INSTALL command it will not show up in the ARP list.
My script has NATIVE_ENGINE set to true... so I guess I will just remove the apply intall commands.
Sound correct?
Postby FrancescoT » Wed Nov 18, 2015 12:41 pm
Dear George,
this also depends if you used the "DELAYUNTIL_APPLYCHANGES" pre-defined variable with your native code.
"DELAYUNTIL_APPLYCHANGES: This variable has no effect unless the native code setup engine is being used. Initially FALSE. If this variable is set to TRUE, the native code setup engine will attempt to emulate the behavior of the Windows Installer setup engine by deferring the execution of setup actions until Apply Install has been called. While this may reduce some setup agility, it may be useful in circumstances when emulating setup behavior found in older InstallAware versions is necessary."
So if you used the DELAYUNTIL_APPLYCHANGES pre-defined variable, remove or set it to FALSE and then skip the Apply Install call.
Users browsing this forum: No registered users and 81 guests
