Pin to Taskbar under Windows 10
[email protected]
Post by [email protected] »
Hi Support Team,
in my setup I checked 'Pin to Taskbar' and 'Pin to Start'.
On installation the item is
- pinned to taskbar if the installation runs on Windows 7
- pinned to start if the installation runs on Windows 10
How can I achieve both pinning to taskbar AND start under Windows 10?
Best regards
Michael
Re: Pin to Taskbar under Windows 10
Dear Michael,
honestly I don't see any problem to have both pinning to taskbar AND start under Windows 10.
I am using IA X3 (20.05) and within the correspondent "Create Shortucut" command;
- "Pin to Start Menu", to pin the shortucut under "Start screen" on Windows 10 (in place of "Pin to Start Screen").
- and "Pin to TaskBar".
[email protected]
Hi Francesco,
I also updated to 20.05, but the same behaviour. Probably it has to do with the Application User Model Identifier I used in the Create Shortcut Command.
Can you reproduce it when you are using an App User Model ID?
Best regards
Michael
Dear Michael,
I left such field always empty. Anyway I'll see if the Application User Model Identifier can make any difference.
By the way and for test purpose, you could try to do the opposite.
