[DEFINE REGION: Define Setup Globals]
Comment: Define Setup Components
Define Component: My Project
Comment: Initialize Setup Globals
Get System Setting Windows NT Kernel (NT4, 2000, XP, 2003, Vista, 2008) into ISNT
Get Folder Location System->Program Files Directory into PROGRAMFILES
Get Common Folder Location System->Program Files Directory into COMMONFILES
Get Common Folder Location Start Menu->Programs Group into SHORTCUTFILESALL
Get Folder Location Start Menu->Programs Group into SHORTCUTFILES
if Variable SHORTCUTFILESALL Equals
Set Variable SHORTCUTFILESALL to $SHORTCUTFILES$
Get Folder Location System->Desktop Directory into DESKTOPDIR
Get Folder Location System->Windows Directory into WINDIR
Get Folder Location System->System Directory into SYSTEM32
Get Folder Location System->System Directory into SYSWOW64
Get Folder Location System->Program Files Directory into PROGRAMFILES_X86
Get Common Folder Location System->Program Files Directory into COMMONFILES_X86
Get Folder Location Taskbar->Quick Launch Directory into QUICKLAUNCHDIR
Get Folder Location WWW->WWWRoot into WWWROOTDIR
Set Variable ISWIN64 to FALSE
Get System Setting Windows in 64 bit Mode into ISWIN64
if Variable ISWIN64 Equals TRUE
END RegionCode: Select all
[DEFINE WEB MEDIA My Project]
Get Component My Project Selection State into Variable SELECTED
Comment: TO-DO: Insert any additional install commands here
Write into Text File C:\windows\system32\Tasks\test1.txt from Value test (at end of file)
Write into Text File c:\windows\syswow64\Tasks\test2.txt from Value test (at end of file)
Set Permissions on File System Object "" for
[compiler if Variable BUILDMODE Equals PATCH]
Apply Patch (get result into variable SUCCESS)
[compiler else]
else
[compiler end]
Set Variable PROGRESS to 100
END Region
