Check for Multiple SQL Server Versions
Dame1701
Postby Dame1701 » Fri Jan 08, 2016 6:08 am
Hi Guys,
I've nearly finished our installer, but need to perform just a few more tweaks. One of these is to detect whether SQLServer 2008 - 2014 is already installed. If none of these are found then we install SQL Server 2014. I have detection of SQL Server 2014 working (as it came with InstallAware), but I'm wondering how I can modify the script to check for versions of SQL from 2008 - 2014? We need to do this because earlier versions of our product may contain earlier versions of SQL and in those cases we want to leave the existing installation intact.
The script that has generated is:
~InstallAware Clipboard Data~
~Comment~
~{2C103882-7A70-4B48-A734-4C07620EC50D}~
~End~
~{CA30FFCA-6765-4DFE-BF75-63521810E69C}~
~Terminate Install~
~{C9450190-7A54-4F69-A380-2614A199110A}~
~MessageBox~
~{BEC80722-C90A-4C42-911F-BEF35EFF4B2E}~
~$TITLE$ Setup~
~$TITLE$ requires a 64 bit operating system. Please upgrade your operating system and try again.$NEWLINE$$NEWLINE$$TITLE$ Setup cannot continue.~
~3~
~1~
~Else~
~{02B7C5F9-B0A5-4AE6-9685-D317EFC5F880}~
~Set 64 Bit Mode~
~{A70A2271-C849-442E-A942-6BC674A722EB}~
~TRUE~
~FALSE~
~FALSE~
~End~
~{4B8A1CAF-9FA4-4581-A04D-00509BC69348}~
~Set Variable~
~{001BA1E5-CDBF-4A40-8FDE-B0D73AD8BB5F}~
~MSSQL2014_X64$MYAH$MYAH$FALSE~
~TRUE~
~Else~
~{AB9E7CDF-32D2-484F-8562-21751497A8EB}~
~Set Variable~
~{1BAB57BA-AAF0-4D10-92DB-4AF27A207856}~
~PRELIST$MYAH$MYAH$FALSE~
~$PRELIST$$NEWLINE$Microsoft SQL Server Express 2014 sp1 (x64)~
~Set Variable~
~{071891EA-A976-4726-B846-73073D511005}~
~PREREQ~
~TRUE~
~Set Variable~
~{A571124A-ABCD-4194-BF9A-91F12FBC837C}~
~FALSE~
~Comment~
~{A3574295-3EE0-4296-9D6A-8657E45BCF31}~
~End~
~{9CB8BB1A-758D-460E-945F-4F2AE37C7BBF}~
~End~
~{0187819E-602B-4437-8F38-5D2D2C23671B}~
~End~
~{678F7C52-4B95-4A12-9FC7-48EFD51ABEB8}~
~End~
~{A5FAD396-B102-4DB9-AEF6-AE131532C882}~
~Terminate Install~
~{100F0053-2D91-4DCC-988C-27194AEB9005}~
~MessageBox~
~{2C5CEE15-33EA-41FF-B780-2AB06D2E33EB}~
~$TITLE$ Setup~
~$TITLE$ requires at least Windows 7 or later. Please upgrade your operating system and try again.$NEWLINE$$NEWLINE$$TITLE$ Setup cannot continue.~
~3~
~1~
~Comment~
~{B9B92434-7857-4822-8EDD-B2AF0E331C73}~
~at least Windows 7 is required~
~Else~
~{0E9A97B3-B871-4BE4-90DD-C3448A360BC6}~
~End~
~{B0BCC090-2627-40E4-9A81-36B5B3BF2FF6}~
~Terminate Install~
~{AA05DF29-69CC-4218-BAAF-DF53A589BEB2}~
~MessageBox~
~{E53A3502-3CBF-4DDF-B75C-1D7EF4399E39}~
~$TITLE$ Setup~
~$TITLE$ requires at least Service Pack 1 or later. Please upgrade your operating system and try again.$NEWLINE$$NEWLINE$$TITLE$ Setup cannot continue.~
~3~
~1~
~If~
~{7BCB6AEA-E7B1-445A-8B02-B3BE80D49FEA}~
~OS_SP~
~0~
~FALSE~
~FALSE~
~Get System Settings~
~{E0152DBC-52AF-4382-9736-7330F6BA4E96}~
~OS_SP~
~27~
~Comment~
~{DBA91F29-E882-4213-9E3D-D90786486CD2}~
~For Win 7, at least Service Pack 1 is required~
~If~
~{D1167F81-69B0-42CD-9672-FAB5444A4137}~
~MSSQL2014_ISSEVEN_X64~
~0~
~TRUE~
~FALSE~
~Else~
~{367F7239-EB54-4BAD-9771-A16B17C13FB7}~
~End~
~{AD3636B6-CA8B-46A1-BBD7-F645DC7F4D34}~
~Terminate Install~
~{B9EF624B-A587-4CA8-92D5-7AAF59613A6B}~
~MessageBox~
~{13E1996D-4E7C-40CB-B3A0-A0B610AAB46B}~
~$TITLE$ Setup~
~$TITLE$ requires at least Service Pack 2 or later. Please upgrade your operating system and try again.$NEWLINE$$NEWLINE$$TITLE$ Setup cannot continue.~
~3~
~1~
~If~
~{671D44E4-40F4-4864-9BFC-BC4A5D9A2866}~
~OS_SP~
~0~
~FALSE~
~FALSE~
~{657A0288-487C-4F69-B9AC-A71C4B910F76}~
~OS_SP~
~28~
~Comment~
~{4D566087-64A2-4C7C-9E40-3089B8365AA6}~
~For Win 2008, at least Service Pack 2 is required~
~If~
~{6E0299AB-E0F5-4095-9EED-C60CAD3B87EA}~
~MSSQL2014_IS2008_X64~
~0~
~TRUE~
~FALSE~
~Else~
~{5079EBEB-5BF5-4E7D-BE67-623341AB139A}~
~End~
~{CD2D9FEC-E926-486B-810E-BFF6812B544F}~
~Terminate Install~
~{85513148-FE6F-477E-9186-73EAAA567AB7}~
~MessageBox~
~{341A599D-CD89-4122-82E1-30D40C27DA0C}~
~$TITLE$ Setup~
~3~
~1~
~If~
~{1FD3D75B-488F-4C39-B889-0033D77D2023}~
~OS_SP~
~0~
~FALSE~
~FALSE~
~{A612A3A2-01EB-45DD-B7D7-9451CD39AA51}~
~OS_SP~
~27~
~Comment~
~{0F9F5A96-191A-4C9F-B1CE-FE3BC277D4BB}~
~For Win 2008 R2, at least Service Pack 1 is required~
~If~
~{2C81FCE9-398D-4002-8FD8-51025DA8C74F}~
~MSSQL2014_IS2008R2_X64~
~0~
~TRUE~
~FALSE~
~Comment~
~{E2EFBB80-F0AC-4591-B069-E02F7529888A}~
~{B04272EC-3BE4-4A0F-AE64-7713B56A5252}~
~79~
~{5CC587B5-BD3D-4DB6-A9A6-17FC07D638E2}~
~76~
~{45139D0D-EDFD-4F66-8B5E-91BE413D7BBF}~
~81~
~Set Variable~
~{0A735161-60BA-4C35-9CB4-E8253F744027}~
~OS_SP$MYAH$MYAH$FALSE~
~Comment~
~{B5718B2E-45DB-4453-B210-77BB2813C453}~
~If~
~{11F34A5E-62AF-4397-AE7F-05E05B9126F1}~
~MSSQL2014_IS8_X64~
~0~
~FALSE~
~FALSE~
~{95497FEF-0393-4847-BE5D-26DD03DC1DE6}~
~MSSQL2014_IS8_X64~
~87~
~If~
~{A63A485C-33AE-46D8-8BEB-906C3E6F57FD}~
~MSSQL2014_X64~
~0~
~NOTINSTALLED~
~FALSE~
~Check Service~
~{319AC558-3739-4CD6-BC6B-483EE9ECDC73}~
~MSSQL$SQLEXPRESS~
~MSSQL2014_X64~
~Set 64 Bit Mode~
~{40356EAA-1C28-415C-962C-0026ABD29BEB}~
~FALSE~
~FALSE~
~TRUE~
~If~
~{FB55876B-8245-4239-96E8-B2B77457821D}~
~ISWINDOWS64BIT~
~0~
~TRUE~
~FALSE~
~{9B1B333F-A72A-4FCE-85A3-9F2E1F0F8FBB}~
~ISWINDOWS64BIT~
~65~
~Set Variable~
~{292AB0F7-607C-413B-A4FB-AF133E0F7ED1}~
~ISWINDOWS64BIT$MYAH$MYAH$FALSE~
~FALSE~
Many thanks,
Damien
Re: Check for Multiple SQL Server Versions
Postby FrancescoT » Fri Jan 08, 2016 12:51 pm
Dear Damien,
I suggest you to have a look at the "Enumerate MS SQL Instances sample" avaialbale with the following link.
http://www.installaware.com/forum/viewtopic.php?f=2&t=6772#p25655
Dame1701
Postby Dame1701 » Mon Jan 11, 2016 6:07 am
Thanks for this Francesco, I have download the sample and have started modifying it to suit my needs. I've just posted another question regarding the use of parse string, which I have presented as a new topic. I need some more information on how to use parse string, in particular how to specify a pattern to retrieve a certain part of a string value.
Many thanks for all you help so far,
Damien
Postby FrancescoT » Mon Jan 11, 2016 11:32 am
:D
Users browsing this forum: No registered users and 211 guests
