Is there anyway to dynamically include a script at compile time.
We have multiple scripts for different install kits that need to be included
ie. Include Script "c://script//#company#//#project#//appsettings.mia"
something like that.
Include Script w/path
Re: Include Script w/path
Dear dgiles123,
you may use the following approach;
Anyway, with the "Include Script" statement you can only select a script which has been previously added to your project ("Include Script" node within the left tree pane of the MSICode view). Due of this, you cannot enter any path in the Include Script command.
[compiler if Variable MYCOMPILER_VAR Equals SOMETHING]
Include Script: myscript.mia
[compiler end]
