Outer/Wrapper MSI Product Code
328543458
Postby 328543458 » Thu Jan 14, 2016 4:33 pm
Is it possible for us to explicitly set the product code on the "Outer" (Group Policy/Active Directory) MSI when generating a single file .EXE? Our corporate IT group thinks this would help them monitor our installations with System Center, right now it is different on every install. The actual product code is nested in a MSI inside a .EXE
Alternatively, if there is some documentation about how to optimally generate MSI's using InstallAware for use with System Center, that could be useful as well.
Thank You
Re: Outer/Wrapper MSI Product Code
Postby FrancescoT » Fri Jan 15, 2016 12:04 pm
if you are referring to the MSI product-code that gets generated at setup Runtime when running an msi install, this value is dynamically generated by the MSI engine directly and cannot be defined ... it's a random value generated at Runtime.
Alternatively, you may give a look at the InstallAware Direct Deploy.
"Direct Deploy complements Microsoft's Group Policy deployment mechanism for MSI files, providing rapid deployment for any EXE installer across an Active Directory network; together with the capability to obtain statistics on installed product versions and repair/uninstall them. Direct Deploy is built upon MSIcode, and all of the Direct Deploy dialogs and deployment logic is fully customizable."
For more information, please consult the InstallAware documentation.
Users browsing this forum: Google [Bot] and 259 guests
