Hi Support Team,
I just inadvertently removed some feature definitions. To reproduce the error please perform the following steps:
- Add a Feature 'Parent Veature'
- Add a child feature 'Child Feature'
- Go back to the parent feature, click it (or press F2 or click 'Rename'), move the cursor to the 'V' and press <del> in order to delete the letter 'V'
Before you have the chance to enter a 'F' the feature including all child features are disappeared. The delete key must not act as 'delete feature' but as 'delete character' when editing the name.
Besides I would expect at least a request for confirmation in case a feature (particularly when sub-features are included) is about to get deleted.
Without that confirmation request this is a very annoying issue, because there is no undo available. The only way is to close IA IDE without save - but than any other change is gone to heaven...
Would you mind to consider this to be fixed?
Best regards
Michael
Inadvertently Removal of Features
Re: Inadvertently Removal of Features
Dear Michael,
many thanks for reporting this!
I'll send a note to our dev team to report this behavior.
[email protected]
Hi Francesco,
Is this implemented in the current release X6?
Best regards
Michael
Best regards
Michael
Dear Michael,
for what I see, this fix will be included with an eventual IA X6 update.
As workaround, you may use the "Back-Space" key (<-) to delete a character from a feature name.
Dear Michael,
this should be now fixed with the latest IA X6 update (v. 23.02 - Released to Manufacturing on: 03.04.17)
