Translation Issue.
athapa
Translation Issue.
Post by athapa »
Hi I am new to Installaware. I inherited this part from my co-worker who left the company. Any how i am translating Installaware to few language and it works for some and doesn't work for some. For eg. It doesn't work for chinese and Arabic. I already translated translations.Arabic and translations.Chinese (PRC) as well as shared.translations files also. If i open them through notepad i can see arabic and chinese language but if i use your mTranslator.exe its shows some different character. Also it doesn't display the translated word when i run.
Thank you
Any help will be appreciated.
Re: Translation Issue.
Dear Athapa,
I suppose you are using an old InstallAware version where UNICODE support was not available.
You may have a look at the following threads for a similar question.
http://www.installaware.com/forum/viewtopic.php?p=18842
http://www.installaware.com/forum/viewt ... 38&start=0
In addition, I suggest you to follow the steps described with the "translation tool.pdf " from:
http://www.installaware.com/forum/viewt ... f=2&t=6772.
