i wonder what is the size of the "Call dll Function" parameters in bytes? word, double word, long
What C data types are used internally by InstallAware to call the function?
Thanks Jochen
Call DLL: size of word, double word, long
JochenBaier
Re: Call DLL: size of word, double word, long
Dear Jochen,
I am sure you can understand why I cannot share such details... I can only say that the call stack gets dynamically allocated.
JochenBaier
Hi,FrancescoT wrote:Dear Jochen,
actually not, because this information is important to use the API correct. Which Function Parameter Types (Word, Double Word etc) do i need to call this function:
void (int8_t a, int16_t b, int32_t c, uint8_t d, uint16_t e , uint32_t f);
Thank You, Jochen
Dear Jochen,
if I haven't missed your original question, you was asking how the "Call Dll Function" is capable to handle the called function stack.
...but it seems that I have totally missed your question indeed!
Anyway, for all your function types you may use the "long type parameter" with the "Call Dll Function".
JochenBaier
Thank you FrancescoFrancescoT wrote:Dear Jochen,
