Place version number in output filename
Dame1701
Post by Dame1701 »
Does anyone know if there is a way to put the version number in the Output filename (as set in Build Settings under Deployment. We want to output a filename such as ContentAgent 3.4.5.11 Installer where the 3.4.5.11 comes from the version variable (which I believe is defined as $VERSION$). I have tried ContentAgent $VERSION$ Installer but this just outputs $VERSION$ rather than 3.4.5.11.
Is this possible, and if so how can we achieve this?
Many thanks,
Damien
Re: Place version number in output filename
Dear Damien,
did you have a chance to look at this?
http://www.installaware.com/forum/viewt ... f=2&t=8927
Edhy
Post by Edhy »
Hi Francesco,
I have the same need to place the version number in the output filename ex: MySetup_v1.1.5.exe.
I looked at the thread you posted here and even downloaded the sample application you posted demonstrating how to set a Tile and Version variables using a compiler variables which is nice, but I cannot find anywhere in these messages where to setup the Output File value programmatically?
Is there any OutputFileName variable somewhere we can update using our compiler variables for the version number?
I basically would like to be able to enter something like this in the Output filename field: $TITLE$_v$VERSION$.
Any help will be greatly appreciated.
Edhy Rijo
Dear Edhy,
it's not available a pre-defined compiler variable at such purpose ... you may use a custom compiler for that.
At any rate and assuming the same sample project, you may simply do as follow with the build settings.
Edhy
Post by Edhy »
Hi Francesco,
Thanks for the prompt reply.
Great, it worked!!!
Edhy Rijo
:D
