Restart Windows Explorer plugin.
bokkie
Postby bokkie » Thu Apr 21, 2016 3:54 am
Folks,
One of the forum members asked about how you can restart the Windows Explorer. I did some research on the subject and I wrote a plugin which is attached. It seems to work okay (at least on my machine). Unzip the file, run the installer and in the MSIcode you'll see a plugin called Restart Windows Explorer.
Peter.
Edit 22/April/2016: New plugin uploaded. I fixed a teeny glitch where the dialog Cancel button wasn't cancelling correctly. It now does. :oops:
Restart Windows Explorer plugin.7z
(2.59 MiB) Downloaded 6981 times
SteveDude
Re: Restart Windows Explorer plugin.
Postby SteveDude » Tue May 03, 2016 12:18 pm
Thanks Peter! I do shell extensions so that will be handy. I attached an EXE I've been using to accomplish the task.
RestartExplorer.zip
(6.31 KiB) Downloaded 6383 times
bokkie
Postby bokkie » Wed May 04, 2016 3:09 am
Thanks Steve. I ran your exe and it got me thinking about how you achieved your restart?
In my plugin, the nitty-gritty is done with:
foreach(var p in Process.GetProcesses().Where(p => p.ProcessName.ToLower().EndsWith("explorer")))
p.Kill();
break;
Process.Start("explorer.exe");
Does your exe do something similar? I'd be interested to know if there are other ways of doing it. I know the WMI namespace offers classes that can discover process names using more reliable methods. From what I could find, the Process class seems to be where the smart money is?
SteveDude
Postby SteveDude » Thu May 19, 2016 5:18 pm
Sorry it took me so long to reply. Been on vacation and goofing off, but yes, I'm doing pretty much the same thing...
using System;
using System.Diagnostics;
using System.Threading;
namespace RestartExplorer
    internal class RestartExplorer
        public RestartExplorer()
        private static bool IsExplorerRunning()
            Process[] processes = Process.GetProcesses();
            for (int i = 0; i < (int)processes.Length; i++)
                if (processes[i].get_ProcessName().ToLower().StartsWith("explore"))
                    return true;
            return false;
        private static void KillExplorerProcesses()
                Process process = processes[i];
                if (process.get_ProcessName().ToLower().StartsWith("explore"))
                    process.Kill();
        [STAThread]
        private static void Main(string[] args)
            try
                Process.EnterDebugMode();
                RestartExplorer.KillExplorerProcesses();
                Thread.Sleep(3000);
                RestartExplorer.VerifyExplorerRunning();
                if ((int)args.Length > 0)
                    string[] strArray = args;
                    for (int i = 0; i < (int)strArray.Length; i++)
                        string str = strArray[i];
                        ProcessStartInfo processStartInfo = new ProcessStartInfo("explorer.exe", string.Concat("/n,/e,", str));
                        processStartInfo.set_UseShellExecute(true);
                        Process.Start(processStartInfo);
                Process.LeaveDebugMode();
            catch (Exception exception)
        private static void VerifyExplorerRunning()
            DateTime now = DateTime.get_Now();
            while (!RestartExplorer.IsExplorerRunning())
                Thread.Sleep(200);
                if ((DateTime.get_Now() - now).get_TotalMilliseconds() <= 5000)
                    continue;
bokkie
Postby bokkie » Fri May 20, 2016 2:58 am
Thanks. I was thinking of shopping around to use something else but I'm happy knowing that we both more or less do the same thing. :)
SteveDude
Postby SteveDude » Fri May 20, 2016 1:09 pm
...I was going to take it a step further using LockWindowUpdate so you wouldn't get the flash when Explorer is restarted but haven't went there yet.
bokkie
Postby bokkie » Sat May 21, 2016 10:36 am
LockWindowUpdate? I haven't come across that one before. I'll have a look for information about it and see about adding it to the plugin. Thanks for the heads-up on it.
Edit: I have an entry for it in my copy of Dan Appleman's book on the Windows API.
SteveDude
Postby SteveDude » Sat May 21, 2016 1:05 pm
Just use it with the Desktop Handle and then 0 to unlock. I use it every so often displaying complex dialogs.
bokkie
Postby bokkie » Sun May 22, 2016 5:07 pm
You mean something like the following?
var handle = GetDesktopWindow();
LockWindowUpdate(handle);
LockWindowUpdate((IntPtr) 0);
When I run this code the bit in the middle, the ... is where I have my code to restart the explorer. It still flashes on the monitor. My definition for the GetDesktopWindow and LockWindowUpdate methods is correctly defined. My window handle returns a positive IntPtr value. Anything obvious that I'm missing?
By the way, you could have told me that stepping into the code where the ... is does nothing, because the desktop handle is locked and with it, so is every window on the desktop. :D
Users browsing this forum: No registered users and 76 guests
