]Is there any way to adjust the size of the initial dialog that the program displays when it is unpacking and verifying files? The dialog is too small for the french translation of the string it contains. I am not set up for testing in many other languages, but I would imaging that some of the more wordy ones might have similar problems.
[attachment=0]clipped.png[/attachment
Initial dialog is too small for the defualt text.
- clipped.png (24.02 KiB) Viewed 3427 times
Re: Initial dialog is too small for the defualt text.
Dear Rentzk,
you may try to update the file dependent.exe in your main InstallAware folder using a resource editor. This file contains all initialization dialogs.
