X4 is I think supposed to provide hybrid 32 and 64 setups, within the 64 setup template.
How does it work? Do you simply add your file destinations as if you were creating a 32 and 64 bit setup on one setup, and then let the installer detect whether the user is using a 32 or 64 bit edition of Windows?
Hybrid 32 and 64 bit SetUp
Re: Hybrid 32 and 64 bit SetUp
Dear Emmertonland,
did you have a look at the following topic?
http://www.installaware.com/forum/viewtopic.php?f=2&t=8492
Thanks I am studying the example for implementation.
Users browsing this forum: No registered users and 161 guests
