Code Signing Problem
SteveDude
Postby SteveDude » Tue May 03, 2016 11:40 am
Trying to figure out what's going on with X4 Code Signing.
I'm using a PFX file and with X3 it worked fine.
The first build of X4, code signing failed in the installer but worked with the Code Signing tool.
I just updated to the latest build and code signing fails all together.
Any ideas on this?
Re: Code Signing Problem
Postby FrancescoT » Tue May 03, 2016 1:37 pm
Dear Steve,
can you post the command line you used with signtool?
Did you used the latest signtool version?
SteveDude
Postby SteveDude » Tue May 03, 2016 3:49 pm
I was just using the Installaware Code Signing Tool which does seem to be working now, but it doesn't work on build within the installer. I tried using the tool 3 days in a row and failed every time for two of them and today, magically it started working. Not sure what was up with that. Might of been me.
In the installer I'm not using any command lines, but just the default settings under Authenticode Options. The signtool version is the one that comes with IA in the latest build.
SteveDude
Postby SteveDude » Wed May 04, 2016 3:15 am
My Mistake...duh...
Postby FrancescoT » Wed May 04, 2016 11:39 am
Happy you solved!
Users browsing this forum: No registered users and 157 guests
