Adjusting system settings like Power Saving
jessican
Postby jessican » Fri May 13, 2016 9:20 am
Hi! I was wondering if anyone could advice the best way to go about adjusting system settings such as power saving during installation? Thanks!
Re: Adjusting system settings like Power Saving
Postby FrancescoT » Fri May 13, 2016 11:07 am
Dear Jessican,
you may use "Powercfg.exe" for managing power options from the command line.
https://technet.microsoft.com/en-us/library/hh824902.aspx
Then you can call such tool from your MSI code script using the "Run Program" command.
jessican
Postby jessican » Mon May 16, 2016 8:33 am
Thanks so much!! :D
Postby FrancescoT » Mon May 16, 2016 11:20 am
:D
Users browsing this forum: No registered users and 140 guests
