I have built my installer and all is working well but when the password entry dialog appears
if I enter an password that is incorrect I get a dialog box stating
"Cannot Start Setup - Setup file may be corrupt or you may have entered the wrong password...
Then installer completely closes.
Is there a way to reference that the password was entered incorrectly and return to password
entry screen instead of launching the installer all over again?
incorrect installation password closes installer
randyengle
Re: incorrect installation password closes installer
Dear Randyengle,
unfortunately this is not possible.
