InstallAware setups don't write the value EstimatedSize into the registry. So, we would like to do this ourselfs.
On the destination form there is a value for "Space Required" and a StaticText control that receives information from "Total required space".
Is there a way to get the value into a variable to use it for later purposes?
Getting estimated size and writing it to the registry
Re: Getting estimated size and writing it to the registry
Dear Pfennig,
Please have a look at the following links;
http://www.installaware.com/forums/viewtopic.php?f=2&t=8750&p=32156&hilit=estimated+size+ARP#p32156
http://www.installaware.com/forums/viewtopic.php?f=6&t=1865&hilit=estimated+size+ARP
You may use the "Get Component Space" command to get the space requirements of a component previously defined by the Define Component command.
Yes it helped indeed, thank you
Users browsing this forum: No registered users and 73 guests
